LVSMT Series
12-20 kW | Three phase | 3 MPPTs
Scrollen
undefined
Low voltage
Latin
98.8%
undefined
undefined
undefined
Max. efficiency up to 98.8%
Full-load running at 50°C
String level monitoring
130% DC input oversizing
110% AC output overloading
PLC Communication
undefined
Low voltage
Latin
98.8%
undefined
undefined
undefined
200V-950V Wide MPPT Volatge Range
Compatitable with High Power Module
DC input current 15A
OVERZICHT
GW12KLV-MT
Max. ingangsspanning (V)
800
2/2/2
Max. rendement
12
Nominale uitgangsspanning (V)
220V,3L/PE
GW15KLV-MT
800
2/2/2
Max. rendement
15
220V,3L/PE
GW20KLV-MT
800
2/2/2
Max. rendement
20.7
220V,3L/PE
NIEUWSBRIEF
Detailhandelaar
Eindgebruiker
Anderen
Verificatiecode invoeren:*
